Cleaning factory best replica rolex oyster perpetual?
The CLEAN Factory Rolex Oyster Perpetual 124300 has been making waves in the replica watch community, particularly for its 3230 movement and near-perfect replication of the genuine model. In this detailed review, we’ll break down every aspect of this watch—from case construction and dial accuracy to movement performance and bracelet quality—to determine whether it truly deserves its reputation as the best Oyster Perpetual replica available today.
1. Case & Build Quality – 904L Steel & Precision Engineering
The 41mm case is crafted from 904L stainless steel, the same alloy used by Rolex, ensuring exceptional corrosion resistance and a premium finish. CLEAN Factory’s attention to detail is evident in:
  • Case Shape & Thickness (11.7mm): Nearly identical to the gen, with correct curvature and polished/brushed surfaces.
  • Lug & Crown Proportions: The lugs are properly tapered, and the screw-down crown features a deeply engraved Rolex coronet.
  • Water Resistance: Rated at 100m, though we recommend avoiding deep diving with any replica.
Comparison with Genuine:
  • Weight & Feel: The heft and balance match the gen, thanks to 904L steel.
  • Flaws: Minor differences in case-back engraving depth, but unnoticeable when worn.
2. Dial Accuracy – Sunburst Finish & Perfect Printing
The Balloon dial is one of CLEAN’s strongest points:
  • Color Matching: The Balloon dial variant is 98% accurate, with only a slight variance in extreme lighting (vs. gen’s six-layer lacquer process).
  • Index Alignment & Lume: Applied markers are perfectly positioned, with Swiss-grade Super-LumiNova that glows strong and even.
  • Text & Logo: The "ROLEX" font and coronet at 12 o’clock are crisp, with no bleeding or misalignment.
Key Differences vs. Gen:
  • The gen’s dial has a slightly deeper gloss due to Rolex’s proprietary finishing, but CLEAN’s version is impressively close.
3. Bracelet & Clasp – Oyster Perpetual’s Signature Comfort
The three-link Oyster bracelet is a highlight, featuring:
  • Solid End Links (SEL): No gaps or rattling, just like the gen.
  • 904L Steel Construction: Brushed center links and polished edges mirror the genuine Rolex design.
  • Clasp Mechanism: The folding clasp snaps securely, with a correctly engraved coronet (though the stamping is slightly shallower than gen).
Wearability:
  • The bracelet feels smooth and flexible, with no sharp edges.
  • Adjustment: Lacks the EasyLink extension (not present on the gen OP), but the glide-lock system is well-executed.
4. Movement – The 3230 Clone (Stability & Reliability)
The biggest upgrade in CLEAN’s Oyster Perpetual is its clone 3230 movement:
  • 70-Hour Power Reserve: Matches the genuine Rolex 3230.
  • No-Date Function: Simplifies the movement, reducing potential flaws.
  • Rotor Noise: Slightly louder than gen, but only noticeable in a quiet room.
Performance Testing:
  • Accuracy: Runs at ±5 sec/day in testing, comparable to many genuine luxury watches.
  • Longevity: Early reports suggest strong reliability, but servicing may be needed after 3-5 years.
Comparison with Other Factories:
  • VS Factory: Uses a modified ETA 2824 (less gen-like).
  • EW/King Factory: Lower-tier movements with poorer accuracy.
5. Common Flaws & How to Spot a CLEAN Factory OP
While CLEAN’s version is extremely close, some tells include:
  1. Rehaut Engraving: The "ROLEX ROLEX" rehaut text is slightly less sharp than gen.
  2. Caseback Engraving: The serial/model numbers are laser-etched (gen is deeper).
  3. Rotor Noise: A faint "whirring" sound when shaken (gen is near-silent).
How to Avoid Fake CLEAN Factory Watches:
  • Check the Dial Color: Some lower-tier reps have off-green hues.
  • Movement Verification: Only CLEAN uses a true 3230 clone (not a decorated 2824).
6. Final Verdict – Is This the Best Oyster Perpetual Replica?
Rating: 9.7/10
  • Near-perfect dial & case finish
  • 904L steel construction
  • Reliable 3230 clone movement
  • Superb bracelet quality
  • Rotor noise (common in reps)
  • Minor rehaut imperfections
  • No true waterproofing guarantee
Who Should Buy This?
  • First-time rep buyers (easy to wear, low-key)
  • Rolex enthusiasts who want a budget-friendly alternative
Discussion Points:
  • Owners of CLEAN OP 124300: How’s your 3230 movement holding up?
  • VS Other Factories: Has anyone compared CLEAN to VS or EWF?
Tags: #Rolex #OysterPerpetual #CleanFactory #ReplicaWatch #3230Movement #LuxuryWatches
