Hello everyone, Rolex is also a very classic brand. At the same time, its watch series are also very numerous, such as Daytona, Greenwich, Yacht, etc. Of course, in terms of sales, the Datejust is definitely the king. After all, the Datejust has many sizes, which meets the wearing habits of watch friends all over the universe. It is precisely because of this sense of detail that it has been favored by many replica watch manufacturers. Of course, in today's replica watch market, there are many manufacturers that make molds for the Datejust, at least dozens of them, but in terms of popularity, VS factory Rolex and clean factory Rolex are two major factions. For these two manufacturers, there are actually many commonalities. After all, many of them use the same accessories factory! This time, we will make a detailed appreciation of the workmanship of the Rolex blue diamond-engraved Datejust of Factory C. For this watch, the overall mold opening is also very good. At the same time, 323 5 movement, also let this watch truly achieve the flavor of both inside and outside.
Clean factory Rolex blue diamond engraved log details parameter appreciation
First of all, the material of the watch is matched with 904 stainless steel. Of course, this material has been popular since the AR factory was popular a few years ago. Until now, the AR factory's exclusive accessories factory is also being cooperated by major factories. Of course, the polishing of the material is very delicate. The brightness of the watch is very comfortable. The watch has also been polished and electroplated. The overall
The watch is very bright! Of course, please note that it does not mean that the watch will not be scratched during the later wear process. After all, the original version will also leave traces in the later period. This means that in the later use process, you take care of it yourself. Many friends who use the original watch will spend thousands of dollars to put a protective film on the watch. Of course, there is nothing wrong with this. Meaning, any watch will get older the more you wear it, and it will not get newer the more you wear it, unless it is used as a decoration!
I have to share here about the bezel. For the Rolex bezel, this time it is still made of 904 stainless steel. It is not that many merchants boast that the replica is a platinum bezel in order to ship. According to the current gold price of 800 or 900, a bezel must be 9 to 10 grams, but the overall C factory watch is only more than 3,000. From here, everyone can do the math. Will the manufacturer sell it at a loss? Of course, the grinding of the triangular pit pattern is very delicate, and the brightness is also very bright. Although it is not made of platinum, the electroplating and grinding of 904 steel can also be the best substitute! At the same time, the craftsmanship of the replica factory is improving, and the bezel will not easily fade. Of course, it must be cherished to avoid bumps and falls!
The mirror is a sapphire mirror this time. Of course, the transparency of the mirror is very strong, which is similar to At the same time, the mirror surface will not be easily scratched in the later stage. There is also a hidden anti-counterfeiting mark unique to Rolex at the six o'clock position of the mirror surface. For this mark, you have to look carefully to avoid overlapping with the scale, so that it cannot be seen. The anti-counterfeiting mark of the C factory is very shallow, not as deep as the previous AR factory. At the same time, the inner shadow engraving of the mirror surface is also very clear. The inner shadow engraving is different for each batch. Remember not to use the code as the only standard for identifying the version! Of course, the text is the highlight of the watch this time. The text is classic blue. The font is also very clear. The scale is diamond engraved, which adds a sense of luxury compared to the bar. For the hands, it is a classic large three-hand. The details of the hands are polished very well. Please note that for any replica watch, there may be a little burr on the scale or hands. After all, in the watch, As can be seen from the above, many original watches cannot avoid these. For those who pursue perfection too much, it is actually difficult to choose a perfect watch, and perhaps the original watch cannot satisfy them! For the three o'clock position, there is a calendar window. For the details, Factory C has done a very good job! The lines on the side of the watch are very comfortable, and the feel is very good. There is no scratching on the side of the watch. For this point, many small factories have a certain gap. The engraving on the right side of the watch is very clean. Of course, for the embedded crown, in the later use process, the crown must be turned steadily to avoid the embarrassment of water entering the watch. At the same time, the crown is an external thread style, and the crown will not easily slip. Of course, to be honest, Rolex watches have basically never seen the crown slip after-sales service, perhaps this is also the external thread crown The benefits!
However, the back is still the classic solid bottom design, and the tooth pattern on the back is also very clean. Please note that for C factory and some manufacturers, they like to paste animation patterns on the back. This is a pattern, not something that the watch itself has. At the same time, the pattern of each batch is different. Don’t ask why your family’s photo is this small animation, and the delivery is different, to avoid this embarrassment!
For the movement, this time it is an upgraded version of the 3235 movement. This movement has been gradually upgraded about last year. There are two pillars at the shock absorber of the movement. Here everyone knows that of course, the stability of this movement is very strong. The official C factory said it is 72 hours, which is comparable to the original version. However, for mechanical watches, wearing is very important. At the same time, in the later use process, it is also necessary to avoid bumps and falls, which will cause Physical damage, and magnetic fields should also be noted. For actual use, the after-sales service of Factory C is not high. The movement has a very strong sense of detail. At the same time, as a dense bottom design, the watch will not appear fake at first glance!
For the strap this time, it is matched with a beaded strap. Of course, this combination is also very classic. At the same time, the watch section is also fixed by screws. When using the watch in the later stage, you must also pay attention to the looseness of the screws. Use the screwdriver sent by Niyingjia to check it yourself regularly! This is also the most basic personal maintenance of the watch, and the processing of the details of the clasp is also very strong!
Is the clean factory Rolex blue diamond engraved datebook worth buying?
For the overall workmanship of the watch, Factory C has done a very good job in the processing of details, so that you can experience the original version at a price that is less than a fraction of the original version. This is also very good. For the watch is Whether it is worth buying or not depends on the workmanship of the watch itself, and whether you like this watch subjectively. Only when these two aspects are satisfied can you buy it! At the same time, in terms of pre-sales and after-sales of C Factory, C Factory is very good. Of course, the after-sales of watches may be slower in special periods, but at least it is not like many branch C factories, which are basically one-time transactions. Regardless of after-sales, when buying a watch, you must avoid being counterfeited! This is very important!
Summary: Today, I will briefly explain the workmanship of the C Factory Rolex Blue Face Diamond Engraved Journal. This watch also restores the charm of the original to the extreme. Whether it is the restoration of the appearance or the upgrade of the 3235 movement, C Factory is paying tribute to the original, and it is also the most beautiful answer sheet delivered to watch friends. Watch friends who really like this watch can also consider buying it. Thank you for watching!
