The Best Rolex Oyster Perpetual Replica? Clean Factory Review
The Rolex Oyster Perpetual 41mm (Ref. m124300-0001) is one of the most sought-after entry-level luxury watches, known for its clean dial, robust build, and timeless design. However, its high retail price and limited availability have led many watch enthusiasts to explore high-quality replica watches from manufacturers like C Factory (Clean Factory).
In this review, we will conduct a side-by-side comparison between the Clean Factory replica and the genuine Rolex Oyster Perpetual 41mm, analyzing key aspects such as case construction, dial details, movement, and bracelet quality.
1. Case & Construction
Material & Finishing
  • Genuine Rolex: Uses 904L stainless steel, known for its superior corrosion resistance and polished finish. The case has a perfect balance between brushed and polished surfaces.
  • Clean Factory Replica: Claims to use 904L steel, and in practice, the weight and feel are very close to the genuine model. The brushing on the lugs and the polished chamfers are well-executed, though under a loupe, the finishing may show slightly less refinement.
Case Shape & Dimensions
  • Both watches measure 41mm in diameter and share nearly identical thickness (~11.7mm).
  • The Clean Factory case shape is extremely close, but the crown guards might be marginally thicker than the genuine version.
2. Dial & Hands
Dial Color & Printing
  • Genuine Rolex: Features a flawless sunburst dial with crisp, laser-engraved printing. The "Rolex" and "Oyster Perpetual" text is sharp and slightly raised.
  • Clean Factory Replica: The sunburst effect is well-replicated, but under direct light, the color saturation may differ slightly. The printing is clean but lacks the micro-level precision of the genuine watch.
Hour Markers & Lume
  • Genuine: Uses Chromalight lume (blue emission), with perfectly applied markers.
  • Clean Factory: Uses Swiss-grade BGW9 lume, which is very close in color but may not last as long. The markers are well-aligned, but the lume application can occasionally show minor inconsistencies.
3. Movement: Replica vs. Genuine
Genuine Rolex Caliber 3230
  • A COSC-certified movement with -2/+2 sec/day accuracy and 70-hour power reserve.
  • Features Paramagnetic blue Parachrom hairspring for anti-magnetic properties.
Clean Factory Replica Movement
  • Uses a modified Asian 3235 clone movement (based on Shanghai 3235).
  • Accuracy: Typically ±10 sec/day, with a ~60-hour power reserve.
  • The rotor noise is slightly louder than the genuine Rolex, and the time-setting action is not as smooth.
Bracelet Quality
  • Genuine Rolex: The Oyster bracelet has a solid, refined feel with perfect link articulation. The clasp features a smooth, secure mechanism with Rolex’s Easylink extension.
  • Clean Factory Replica: The bracelet is 90% similar, with 904L steel and decent weight. However, the edges of the links may feel slightly sharper, and the clasp action is not as refined.
SEL (Solid End Links) Fitment
  • The Clean Factory SELs fit well but may have a tiny gap compared to the seamless fit of the genuine watch.
5. Overall Wearability & Verdict
The Clean Factory Oyster Perpetual 41mm is one of the best replica watches available, offering ~90% accuracy compared to the genuine model. The biggest differences lie in:
  1. Movement precision & smoothness (genuine is far superior).
  2. Dial printing & lume application (genuine has finer details).
  3. Bracelet finishing & clasp mechanism (genuine is more refined).
For 90% of casual observers, this replica watch will pass as genuine. However, Rolex experts may spot minor flaws under close inspection.
  1. How important is the movement accuracy in a replica watch? Would you prefer a cheaper replica with a basic movement or pay more for a clone movement like the Shanghai 3235?
  2. Do you think Clean Factory’s 904L steel claim is accurate? Or is it just marketing?
  3. Would you ever consider buying a high-end replica like this instead of saving for a genuine Rolex? Why or why not?
  4. What’s the most noticeable "tell" in this Clean Factory replica compared to the genuine watch?
  5. Should replica manufacturers focus more on movement replication or external finishing?
Let’s hear your thoughts in the comments! 🚀
