Hello everyone, the watch shared today is from the VS factory Omega Seamaster 600m. Of course, there are many watches in this series, and each one is very classic. However, this VS factory launched Omega Seamaster "Deep Sea Black" watch is the peak of the Seamaster series. Similar to the Seamaster 300 Black Warrior, it also uses a pure ceramic case, but the texture is brighter and unforgettable. This time is a simple sharing of the details of this watch!
VS Factory Omega Seamaster "Deep Sea Black" Workmanship Details Explanation
First of all, its appearance design is very attractive. The orange embellishment adds a touch of bright color to the whole watch, and the addition of the GMT hand further enhances its practicality and ornamental value. Compared with the single black disk of the Black Warrior, this "Deep Sea Black" is more colorful visually. The polished flange process of the case makes it wear for a long time without fading, but it should be noted that this polished outer ring is easy to be stained with fingerprints, but it can be removed with a light wipe. The dial design is clean and neat. The choice of ceramic material not only improves the appearance, but also ensures the brightness and flatness of the dial.
The order of the pointer is exactly the same as the original. From the second hand, minute hand, hour hand to the GMT hand, every detail has been carefully polished. The sapphire mirror is coated with a blue film, which is transparent and clear, complementing the ceramic font. Under the illumination of the light source, the three Arabic scales 6, 9, and 12, as well as the metal frame, the nail scale, the four needles and the Omega logo all shine brightly. The GMT scale is cleverly placed in the inner shadow, which is both practical and does not affect the overall beauty. The alternating brushing and polishing process on the side of the case makes the junction contrast sharply. Although the helium exhaust valve on the left is only decorative, it also reflects the VS factory's control of details. The crown adopts a triangular pit design to facilitate the adjustment of time and calendar.
The characteristics of the ceramic case make it corrosion-resistant and scratch-resistant, and it can remain as new even after long-term wear. The transparent back design allows the movement to be seen at a glance. The VS8906 movement evolved from the Omega AL.8500 series movement. It is an integrated movement and does not require deck modification. The black movement's large balance wheel, double barrels and gear components are all coated with black DLC, which produces a gradient effect as the light changes.
In terms of function, this watch adopts a two-way winding design with high winding efficiency, and the double barrel provides a power reserve of more than 60 hours. Although the movement is different from the original in terms of adjustment error (the difference between a carded and a non-carded hairspring), this does not affect its wearability. In terms of the bottom cover, the VS Deep Sea Black uses the same Naiad technology as the original, which allows the bottom cover to be easily locked and ensures that the waterproof performance and orientation are not offset. The strap uses an integrated natural textile rubber tape, which is comfortable and durable to wear.
In general, the VS factory Omega Seamaster 600 "Deep Sea Black" watch performs well in terms of appearance, material, craftsmanship and function. Whether it is for daily wear or collection, it is a highly recommended watch. Thank you for watching!
